TPI help
Old Jul 9, 2003 | 09:18 PM
chevy_guy_tx's Avatar
TPI help
I bought the TPI intake, plenum, runners, fuel railing, injectors, and throttle body all for $140. I plan on buying a new throttle body(52mm hopefully), 22lb/hr injectors, and most likely a new intake to fit my motor. there in lies the problem. I am putting this on a 70 model chevy pickup. I know I need the computer, wiring harness, and an external fuel pump. But what else do I have to do? Do I have to have the MAF, and the O2 sensor? I know I either have to buy the newer style heads like the original motor had or else buy the Edlebrock intake that fits the late model head. I have a pair of 882's I bought way before the TPI. The newer style heads would take like a $200 investment so they would hold up enough. It's gonna be running atop a 350 4bolt bored out .30. If someone could give me some tips or tell me how to do this if they have done it before it would be greatfully appreciated.
Old Jul 10, 2003 | 07:45 AM
89formula35O's Avatar
did u get the computer with the tpi setup? im guessing you didnt because you didnt state so. its up to what you want to do, if you want to go MAF then youll need the computer and harness to go along with that setup. if you go SD then you will have to get the computer and harness for that setup. for the heads, go with whatever will make more power, you will thank yourself in the end for puttin out that extra dollar.
chris
Old Jul 11, 2003 | 07:42 AM
daxfas26's Avatar
Car: cobalt ss/sc, 91 z28, 92 z28
Engine: 385 stroker
Axle/Gears: stock 10 bolt 3.73
do u have to have the maf or o2 sensor? yes it will not run without either one of these 2!
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
