Got a good one hear..
Old Jul 12, 2003 | 09:21 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Got a good one here..
Okay my friend has a 87 GTA with a 350 tpi. Now the moron tha had the car before him replaced the motor with a crate remanu. 350. the motors went from 350 to 305 back to 350.
Now after doing a few things on his car my friend ended up grounding out this one power wire for something but that ended up killin the MAF, TPS, IAC, ECM, coil, and ended up the car ran really lean to glow the headers and melt the tips off his new bosch platnum 4+ plugs. well after all that was replaced and everything the car was running but not great. so he replaced the EGR valve and well that didnt change much.
after pullin codes there wasnt any but the car still ran like crap(like a v6 almost). Well the big problem he has now is that the car is running really really really rich as if where u could kill misquitos with the amount of black smoke coming out. my brother replced his injectors becuz suposivly one or 2 where stuck wide open, so he got accel 23lb injectors. after replacing everything and whatnot the car was running good, no black smoke nothing bt the car still wasnt running right.
so figured it was the timing but since the car is now running crappy to where its dumping black smoke again. but cant get a good timming out of it becuz the timming is changing every min and the car could have a nice idle and then it goes to choppy/crappy idle to almost die.
the check engine light did come on but then went off after a few mins.
im clueless what the hell could be wrong with his car, also the O2 sensor has been replaced too.
if anyone can shot some ideas this way that would be great, mainly im sick of seein this car running like this and so is my friend. but basiclly everyone is trying to think of what could be wrong but its probably something simple, if anyone can help thanx. sorry about this being so long but my friend needs the help very bad.
Old Jul 12, 2003 | 09:57 PM
86 IROC's Avatar
Did he replace the CTS? That will make a car run rich.
Old Jul 12, 2003 | 10:34 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
For some reason I doubt its the CTS. Cant hurt to check, but the CTS isnt gonna make his timing jump like it does. I thing either his Distributor is shot or its the timing chain. The computer doesnt pick up any codes, he has a horrible hesitation, and from what i can tell, he has replaced the following: TPS, MAF, EGR, IAT, Idle control motor, injectors, and i think thats it. Ign control module, and a new coil. he has good plugs and wires, and the ECM has been replaced. Do you think that when he grounded the wire, he could have fried the prom itself? Or should we just Molotov cocktail the whole car.
Old Jul 13, 2003 | 01:48 PM
3gc's Avatar
3gc
Car: Z28
Wo Brian posted here. lol
Could you get a scanner hooked up to it to see if the coolant temp sensor is bad? Not sure how to tell if a prom is bad but you can get one for like $40 new from GMpartsdirect.com or get the equipment to burn your own for a few hundred.
Old Jul 14, 2003 | 09:45 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Take that car to a mechanic already!!
Old Jul 14, 2003 | 11:01 PM
bigals87z28's Avatar
Car: Check The Sig
i think that steve is just a dumbarse.. but thats me.... i didnt even ready the new problemes he has now...
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
