hard cold starting
Old Jul 13, 2003 | 01:23 PM
a_seiler604's Avatar
Car: 89 IROC-Z
Engine: 5.7 L V8
hard cold starting
I recently replaced the fuel pump, fuel filter, and fuel pressure regulator in my '89 5.7L IROC. The car runs great when the engine reaches 150 degrees and above, but it has some major problems starting. After turning it over for about 20 seconds, the engine finally sputters to life, but it's still really sluggish for about one minute after starting. However, I don't have any problems starting it when the engine's hot. Could it be something with the cold-start valve or injection swith?
I never had this problem before replacing the fuel system components mentioned above.
Any ideas?
Old Jul 13, 2003 | 11:58 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Re: hard cold starting
Any ideas?
What made you replace all those things to begin with?
Old Jul 14, 2003 | 04:37 PM
Car: 89 IROC-Z
Engine: 5.7 L V8
I replaced the fuel pump because it burned out; the fuel filter because it's just prudent to do that sort of thing; and the FPR because the adjustable one that was already on my TPI fluctuated way too much. The FPR must have been a cheap one because it operated within a whole 10 psi range (and I had a high-quality guage to test it). I simply replaced it with a stock one.
Old Jul 15, 2003 | 09:48 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
if it's a 89 it has no cold start injector. in 89 it was eliminated and instead all 8 main injectors fire additional fuel for cold starts. you may have a problem with your injectors. have performed a tune up on the car? it could also be a failing cts or other sensor that the ecm uses for open loop operation. what the history on maintenance peformed on the car besides that already metioned?
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
