Questions before ditching my tbi for tpi
Old Jul 15, 2003 | 11:52 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
A buddy of mine is selling me an 85 tpi setup for dirt cheap. I know 85 was a bad year for tpi, but I have a few questions. In an old post I found someone mention that midway through the 1985 production run, GM switched over to the setup they used in 86. From what I understand, the difference is a different MAF sensor and the 165 ECM instead of the 85's 870 ECM. Is the harness the same from 85 to 86? Is a speed density harness different from the 86 version harness?
Basically, my main question is whether or not I will have problems getting things to work after the swap (i.e. 85 had mechanical speedo, and my 92 has a vss, which I believe is controlled by the 746 ECM but not by the 870). Are there any other computer controlled functions that would be a problem with the 870 ECM? If there is, should I sell the 85 ECM and harness and be able to use the tpi unit with a 730 ECM and a speed density harness?
Old Jul 16, 2003 | 08:14 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
If you leave your old harness in there your gauges will still work you might have to disable vats but other than that it shouldnt be a problem. Also in 85 the tpi only came with an auto if im not mistaken so thats somthing to look into.
It is much easyer to get a setup for closer to your cars year like like to find a 91-92 tpi setup harness sensors and all.
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
