Injector-retainer clip???
Old Jul 18, 2003 | 07:50 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
I brought my car to a shop and they lost the clip for the #1 cylinder injector, they just used a peice of wire in it's place. Can I buy these thing's?? Also, I can put my finger on every injector and feel them clicking, except for the one that the clip is not in. If I push and hold it in the fuel rail while the car is running, then I feel it click(or pulse). And yes when I unplug it, the car start's to get rough idle(so I think it work's fine). I changed them when the shop told me that was the problem, so they are all new accell injectors.
Old Jul 18, 2003 | 08:34 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Are you talking the clip on the electrical connector or on the fuel injector where it connects to the fuel rail? The one on the fuel rail is not neccessary. The one on the electrical connector should there to keep it from vibrating off. I have not seen the clips available by themselves, however you may find some in a salvage yard. The complete connector is available as a repair kit from GM or Delco.
Old Jul 18, 2003 | 09:07 AM
Car: 91Z
Thanks for the reply, I meant the one that holds the injector in the rail, not the electrical conn. I know you don't really need them, but it makes me feel better knowing all of the injector's are set properly.(I think I am to much of a perfectionist )
Old Jul 18, 2003 | 09:48 AM
ULTM8Z's Avatar
GM wants too much money for them. So I simply went to a wrecking yard and found a bunch of late model Oldsmobiles that had the same clips. Picked up 16 of them for fifty cents.
Old Jul 18, 2003 | 09:55 AM
Car: 91Z
Thank's man, I'm gonna check on that after work.
Old Jul 18, 2003 | 10:31 AM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
Damn, you're gonna pull it apart just to put one clip on an injector? :hail:
I give you credit cause I sure as hell know I'd never do that
Old Jul 18, 2003 | 10:32 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
91wtROH17's - What exactly do you mean when you talk about the clicking the injectors make? I'm trying to troubleshoot something and that sounds framiliar.
Old Jul 18, 2003 | 10:44 AM
Dano 00TA's Avatar
Engine: LS1/L98
Maybe I can answer for him. All the injectors should make a slight "clicking" sound while the motor is running. You can feel them or better yet would be to use a stethoscope(sp) or hold a long screwdriver against em and hold it to your ear. They all should be doing it.
Old Jul 18, 2003 | 11:09 AM
Car: 91Z
LOL, No way would I pull it apart just for that!! The motor is being rebuilt soon, so I just want the clip for reassembly.
I think I can't feel the clicking because the injector is not high enough in the rail. Atleast that what my mechanic buddy tell's me, but he said that it was no big deal.
Old Jul 18, 2003 | 12:17 PM
Dano 00TA's Avatar
Engine: LS1/L98
You should still feel it though. Is the car misfiring?
Old Jul 18, 2003 | 12:48 PM
Car: 91Z
Not misfiring at all, run's great!! I can feel it click when I push the injector into the fuel rail more, It's weird.
Old Jul 18, 2003 | 01:34 PM
Dano 00TA's Avatar
Engine: LS1/L98
Well, if it's running great apparently the injector is pulsing. I wouldn't worry about it then.
Old Jul 18, 2003 | 01:40 PM
Car: 91Z
I guess your right. Just was kind of odd that's all.
Old Jul 20, 2003 | 04:53 AM
raystoy's Avatar
That sounds like the type of shop I would stay away from. Good thing they didnt lose the fuel rail! They should have replaced it with the proper part and not have used bailing wire to hold it in place.I would have never accepted that type of shoddy workmanship. They lost it, Demand they replace it!
Old Jul 20, 2003 | 11:36 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
those little pieces of crap! i destroyed four of them, just tyring to figure out how they came out of the fuel rail!
Then, silly me, i figure some local parts store would stock them. GUESS AGAIN!
and GM wanted $6.50 a PIECE for them!!! For a little piece of metal smaller than my pinky finger! Arggg.
After 3 days of running around, i finnaly gave up and fabricated my own.
Its just a small snap ring, with the insides filed off and a a little shorter. works great!
Old Jul 21, 2003 | 06:28 AM
Car: 91Z
Ya, I was not happy with the shop, but I did not notice it was gone until 2 week's later when I took it all apart again to change the injector's. They also scratched up the runner's real good aswell!!! Pi**** me off because it took me forever to polish them in the first place.
RS Reaper
Oct 17, 2018 07:52 PM
Night rider327
Feb 25, 2016 09:50 AM
92-Formula
Dec 12, 2015 10:34 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
James Sutton
Sep 23, 2015 01:56 PM
