TPI to carb
Old Jul 24, 2003 | 12:09 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
TPI to carb
i want to switch my 350ci L98 TPI to a carb. what do i need to complete the swap? im getting rid of my tpi because i crashed my '88 gta and i bought a '86 trans am with no engine (but it was carbed before) and i dont feel like throwing all the wires and computers in the new body. plus i hear you can gain up to 30hp and i can get like $200-$300 for a whole tpi setup on ebay
Old Jul 24, 2003 | 01:49 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
A quick search would yeild you lot's of info...but mainly you'd need..
Intake
Carb
Vac Advance distributor (at least a mechanical advance, but use vac advance for mpg's)
New fuel pressure regulator
Some wiring to the distributor, different plumbing for the fuel lines, if you're going to keep the 700r4, you'd also want some lockup switch setup (manually or automatically) for the TC, if you pull the ECM.
You might also need something to convert/run the speedo as well.
Old Jul 24, 2003 | 02:16 PM
Engine: carbed L98
thanks for the reply. im not keeping the 700r4, the body is coming with a T-5...so for that im going to need a new flywheel (externally balanced) and a new clutch(might as well replace it) what else do i need?
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
