Porting stock heads & valve job + seals?
Old Jul 26, 2003 | 10:48 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
hey guys, i was thinking about having my stock heads ported and having a valve job done since i'm not ready to buy new heads/cam yet. i also know my valve seals are needing to be changed, good to do at the same time? and if i'm having a shop do all this what can i expect $$ wise?
any tips on what to have done exactly since i'm not too familiar with head porting and valve jobs is appreciated, thanks!
also - what gains can i expect from this hp or 1/4 e/t wise?
Old Jul 27, 2003 | 09:22 AM
Rosco the Iroc's Avatar
Car: '89 IROC, '14 LTZ Burb, '18 H6 Outb
Engine: 355 TPI /w Vortec
Axle/Gears: 9 bolt 3.27
off the top of my head $300. Depends on your lo-cal and shop-call and find out.
Old Jul 27, 2003 | 08:14 PM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
check out the post in my sig, it should provide you with most of what you need to know. Yes, get the valve seals done at the same time, and have them machined down to clear higher lift. I'd also have it set up for screw in rocker studs at the same time.
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
