Couple LT1 intake swapping Q's
Old Jul 31, 2003 | 10:37 AM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
I know there's been tons of threads on the swap, but I couldn't really find any info on this stuff.
1. My supply fuel line does not want to "click" into place. It will kind of snap in, but it pulls right off. I've take the plastic clip off and tried to bend out the tangs inside of the line, but it still will not click. Any ideas?
2. Did you have to modify the throttle cable bracket? It looks like it'll need cut to fit the throttle cable.
The main problem I'm having is #1, I spent a couple hours playing with it and haven't had any luck. Thanks for any help.
Old Jul 31, 2003 | 10:46 AM
tpi_roc's Avatar
On mine there can sometimes be a first click, if you push it harder and further then you will really get the fuel lines seated
For an auto use a 93 LT1 bracket, and mine needed to be tweaked a tad to hold the throttle cable in place but the bracket was used.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
sreZ28
Aug 14, 2015 07:48 PM
