no start got spark and fuel
Old Aug 13, 2003 | 03:54 PM
nasty355's Avatar
ok cranks fine has spark and fuel.its a 91sd setup in a 81 camaro.i spray starting fluid in and fires right up then dies.everything seems to be working properly.i just went through a problem with no injector pulse and got that figured out.i have 48psi fuel press, and great spark.everthing is timed correctly.isit possible injectors them selves could be shot eventhough i checked the ohms across them and all read 16.5 to 16.3.plugs get kinda damp but thats about it.spray in starting fluid it fired ringht up and willl idle for a couple secounds.well ay info let me know.eric
Old Aug 18, 2003 | 05:32 PM
BoDeaN's Avatar
Car: '86 Transmaro
I had a similar problem when I rewired my fan backwards. It was shorting something out and would only start for a few seconds when I sprayed some starting fluid in there.
Old Aug 18, 2003 | 08:53 PM
nasty355's Avatar
fixed
problem was bad injectors.tested ok across them but only a couple fired.not enough to run got new accels ok now.
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
