TPS over 1.0 volt?
Old Aug 18, 2003 | 11:14 AM
Krag's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 w/TPI
Transmission: 6-speed
TPS over 1.0 volt?
I just installed a new TPS and hooked up the volt/ohm meter (neg on top - positive in middle) and the lowest I can get it to read is 1.410 volts! in full throttle position it will go to 5.0 okay but I would like it to be about .710 volts at "rest".
It's a 406 with a Speed Density TPI.
Has anybody run into this?.... Weird!
Old Aug 18, 2003 | 11:46 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You could hve min idle set too high
Old Aug 18, 2003 | 12:32 PM
Krag's Avatar
Engine: 406 w/TPI
do you mean the throttle blade adjustment? That's something I didn't check because the original TPS I was able to get under 1.volt but it's makes sense as I am fully counter-clockwise if I moved the blade-adjustment back it might come it under 1.0 volt. I'll re-adjust the idle afterwards.
Thanks, I'll try that.
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
