TPI conversion question
Old Aug 20, 2003 | 04:40 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
IS a L69 and a 305 TPI BASICALLY the same, ie, cam, etc etc, minus the tpi? I think my uncle obtained a 305 TPI setup, and was wondering if there would be any noticeable gains in hp/torque/gas mileage. Would it hook up though?
Old Aug 31, 2003 | 01:16 AM
robert1's Avatar
Yeah, it should hook up just fine, as long as you have all of the parts. You'll see a torque increase for sure with TPI, and this means better mileage more than likely. Do it right and adjust it correctly.
Old Aug 31, 2003 | 08:53 AM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
It should work. There is an early and late style bolt pattern for where the intake bolts to the head. Make sure your intake matches the head. Other than that, get a ECM and wiring harness to go with it and why not put in a little cam?
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
