Fuel Pressure Setting
Old Aug 20, 2003 | 04:42 PM
xmind2006's Avatar
Car: '86 Iroc-z28
I just bought a Holley AFPR and was wondering what the best setting (PSI) would be for performance for my car?
It is on a stock '86 Iroc 305 tpi with a ported plenum and air foil currently. I do not have acess to a track or a dyno, so I was wondering if anyone had a recomendation?
Thanks for any insight!
Old Aug 20, 2003 | 07:00 PM
1991 RS 305's Avatar
I've a 85 305 TPI, mods below. FWIW, a friend hooked up a scanner and exhaust sniffer to fine tune fuel pressure to 13:1 (good for power) at WOT. Stock was 43lbs, we ended up at 38lbs. Most of these are over-rich from GM. Lean is mean!
Old Aug 20, 2003 | 07:47 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
just looked it up in my TPIS hints book.....GM recommended 37-43psi for an 86, 305....TPIS has charts recommending alittle more . there chart shows an 87 305 with mass air flow .when adjusted to 50.5 psi it increases to +10.2 tq and +9.7hp over the stock setting of 42 psi ..
Old Aug 21, 2003 | 12:59 AM
xmind2006's Avatar
Car: '86 Iroc-z28
Thanks!
Old Aug 21, 2003 | 02:22 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
1985 computers are way different from 1986-89 computers. The 85's are setup rich and should theoretically be set at 39 pounds from the factory. The 86-89 computers are programmed way leaner. They are also much faster, give better gas mileage, and make my modifed 85 run much smoother...
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
