Broke something!!!!
Car: 1988 IROC
Engine: 5.7 HO TPI
Transmission: 4 spd Auto
That would be the heater control valve, and yes you do need it. Coolant flows through it. They become brittle with age, the good news is they are easily replaced and can be found at most any decent auto parts store for around $15.
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I think and correct me if im wrong but....if your A/C is not working and your not fixing it, you dont need it and can bypass it. I belieave it shuts down the hot water supply to the heater core when you select A/C so that its not heating up that area since heat is not what your after.
But I could be wrong.
Pac J
May 17, 2020 10:44 AM
sjorgens
Oct 1, 2015 07:54 PM
