Anybody fixed idle with this solution....
Old Aug 21, 2003 | 12:04 PM
Cam28_boy's Avatar
I was talking to a known mustang guy, and he said that some mustang guys who made changes to there cars, and have idle problems say by adding a small hole in the butterflys of the TB will smooth out the idle.
Kind of makes sense don't it? Has anybody ever tried this on a third gen? I'm thinking about trying this since I plan on buying a bigger TB in the near future. Let me get some feed back. Thanks
Old Aug 21, 2003 | 12:09 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
That was an old carb trick. You did it so there wasn't a pull on the fuel circuit that you would get if you opened the blades more. On a Throttle Body, just crank it open slightly more. You will need to re-adjust your Throttle Position Sensor, but you knew that.....
theshackle
Sep 17, 2020 08:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
86IROC112
Aug 17, 2015 02:00 PM
