Engine died!!!
Old Aug 22, 2003 | 12:58 PM
Powerlover's Avatar
Engine died!!!
I just got finished replacing a bent pushrod that was causing a mysterious valvetrain ticking. I had the motor idling, and was finishing adjusting the valves, when the motor died. No sputtering. No spitting. Nothing......just died. I figured that it was due to me tightening a valve, and the lifter loosing its prime, but i couldnt restart the car.
I have fire. I have plenty of fuel poressure, but it just wont restart.
I have disconnected the battery and ECU and will retry in a few minutes.
I checked for bad grounds, lose wires, etc.....
What next?
Old Aug 22, 2003 | 01:07 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Is this the inital time starting the TPI swap or not? Why did the pushrod bend in the first place??? Over-rev? I hope you didn't hydrolock it from a bad headgasket or anything (which also could have caused the bent pushrod if so)... Good luck man.
BTW, NICE RX7 project!!!
Old Aug 22, 2003 | 01:15 PM
Powerlover's Avatar
The bent pushrod occured because i used too long of a bolt when bolting on my intake. I had to mod the holes to fit my heads, and the stock bolts were too short. I didnt realize it, but i tightened the bolt right down onto the pushrod. The setup has been running for a few weeks now, but had the ticking. I shortened the bolt, and all was well.....till it died. I was on my last valve to adjust, when it happened.
Im stumped....
Thanks for the compliment!!!!
Old Aug 22, 2003 | 04:34 PM
Powerlover's Avatar
Man this is weird!!!!
When i first got the car running, i had the fuel pump running off of the cars stock wiring (ran all the time). A few days later, i wired it up to the TPI harness. Well, while i was checking things, i checked voltage to the pump while cranking. There was none. The pump would prime, cut off, and not kick on while cranking. So i sawpped the wiring back to the way i first had it. The pump ran, but the car still wouldnt start. Pressing the fitting on the fuel rail, it doesnt seem to be under alot of pressure. I cranked down on my pressure regulator, but not much help there. I have no way of checking the fuel pressure. I pulled the plugs, and there was no gas on them like there should have been.
Its like my VATS decided to take a dump on me or something.
Any suggestions?
Old Aug 23, 2003 | 02:48 PM
Powerlover's Avatar
I just put a fuel pump from a 91 vette in it, so i know it has fuel pressure.
But i cant get it to spark, and my plugs are as dry as a bone.
What now????......PLEASE HELP!!!!!!!!!
Old Aug 24, 2003 | 09:11 AM
Powerlover's Avatar
It was my brand new ignition module.
What causes a brand new module to pop?
eightsixseven
Dec 16, 2024 01:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
