What Would You Do?
Old Sep 1, 2003 | 12:24 PM
JC92rs's Avatar
What Would You Do?
I HAVE A 92 CAMARO Z-28 5SP. I ALREADY HAVE A 350 BORED .30 OVER AND AFPR, FLAT TOP PISTONS, SMALL CAM,K/N'S,MODIFIED AIR BOX,SHORT THROW SHIFTER.EVERYTHING ELSE IS STOCK.
WHAT SHOULD I DO NEXT?
Old Sep 1, 2003 | 01:43 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Two things...
First, tap on the "caps" key
Then exhaust and intake.
Old Sep 1, 2003 | 02:21 PM
bigals87z28's Avatar
Car: Check The Sig
Originally posted by 8Mike9
Two things...
all that and a bag of chips...
looks like you got yourself a nice car. exhaust (headers, cat if needed, cat back).
Porting the plenum. Doesnt cost much if you have the tools already... get new gaskets at port match the runner openings to the gasket. all you really need is a dremmel with a bit. Grind down the EGR walls and other restrictions. That will give you a little more top end. Also, you might want to look into a set of slp runners for more breathing... and then if you really need it, a new intake base... or port the old one. Good tires, a TA rear end girdle for strenght.
