Port lower intake or not...
While gasket matching my entire intake, i noticed the stock tpi gaskets leave no room to port the lower runner to base. The gaskets overlap into the port a little. There is a hump right behind the gasket, that brings the base even in diameter to the gasket. Should i even mess with it or leave it stock? It seems that if i take out that little hump and grind it smoth i will make more turbulence. Any ideas?
If i port it out, it will leave a bigger dead area behind where the gasket contacts the base. Also, when i say hump, i mean how the port on the base is 1/8" wider that the gasket for the first 1/4" into the base, then it shrinks all the way around to the diameter of the gasket port. It seems anything i do to port it will only make the dead area larger. What did all you guys out there do that didnt get the cut-to-fit gaskets?
LT1Formula
20
Nov 14, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
