Elongating center intake manifold bolt holes
Car: 1998 Camaro Z28
Could someone post a pic of what the TPI lower intake manifold center bolt holes should look like after elongationg a '87 or later intake manifold to fit pre-1987 cylinder heads?
Also, I have a chance to buy a post '87 lower intake manifold with the center bolt holes already elongated, however, the center bolt holes are completely opened up. In other words, on the exhaust side it is completely open or cut out.
Does this pose a problem?
Matt
Matt
Re: Elongating center intake manifold bolt holes
Matt
Matt
I agree on looking like A$$. However, I just want several opinions on whether or not leaks would be a problem. Anybody else?
Thanks in advance!
Matt
Thanks in advance!
Matt
Bohn333,
Thanks for the reply. You did see where I said the holes are completely opened up?
I assumed by elongating the center bolt holes folks meant just opening up the holes towards the cylinder head and then using a spacer or something.
I've enever seen one completely cut out on that side. Have you used one like this?
It looks like I am going to have to use a washer (big enough to cover the diameter of the bolt head) that will sit up on top of the intake manifold, not down in bolt hole area if that makes sense. Do you know what I mean?
Matt
Matt
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
