New Intake
Old Sep 13, 2003 | 04:10 PM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
New Intake
Hey, i needed some input and some direction, on what type of intake i should get, i originally wanted the Steath Ram, i fell in love with that one but found out it isnt emmissions legal, and i want my car to stay legal, i know about the super ram already, but does anyone know of anything else out there ?
Old Sep 13, 2003 | 06:14 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
The skinny is this:
The only emissions legal intake setups are the TPI LTR setup, the SUPERRAM, and of course CARBS.
Since you're going with an L98, as you signature suggests, then TPI will work well. You ported the plenum, now get an aftermarket base and runners. A carb setup will work too. The superram will pass emissions, but likes higher rpms than a stock L98 cama nd heads.
This is not to say that a superram won't show better numbers than the LTR setup... it would be held back tho.
Old Sep 13, 2003 | 08:18 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
Originally posted by D Stroy H8
The skinny is this:
What is the LTR Setup ?
Old Sep 13, 2003 | 10:30 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
It is what you have. LTR = Long Tube Runners.
TPI is LTR... so, in order to improve upon the LTR setup that comes with a stock f-body, there are three components.
The plenum needs porting - you have done this already.
The runners need to go! Stock TPI runners are too long and too thin! {Edelbrock, Arizona Speed & Marine, SLP} all make larger runners for our cars. Finally, the base plenum needs to go as well. {Edelbrock, TPiS, ACCELL} make bases for our cars.
As far as the stock stuff goes, the most you can do is port match the runners, and siamese the stock base a little. WHile this will help, it doesn't come close to aftermarket stuff.
Old Sep 14, 2003 | 07:04 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
i'm thinkin about going with super ram, anyone selling them ? or know how much ican get it for
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
