MAF GTA runs like crap
Old Sep 15, 2003 | 03:25 PM
thirdgencompta's Avatar
I built a motor for my car and I can't get it to run for crap, it starts right up, but it won't idle, in fact it shuts off unless I keep my foot on the gas...I basically rigged it up like you would see a TPI if it was on a street rod. I have no EGR hooked up, no vacuum canister. I put plugs on the vacuum ports on the plenum. Could this be a vacuum problem or possibly an injector problem? ANy advice is appreciated. I'm just getting real mad, soon feel like converting to carb, or selling the F%^&in thing
Old Sep 15, 2003 | 04:51 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
Sounds like a bad vacuum leak. Are you using aftermarket intake runners???? If so, it's probably a vacuum leak between the runners and the plenum or intake..... Use a stethoscope to listen for the leak....
Old Sep 15, 2003 | 10:08 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
So it isn't throwing a code at all? It should as the EGR isn't hooked up...also, keep in mind that the street rod tpi setup usually has a Prom burnt to accomodate no emissions, etc.
Old Sep 16, 2003 | 05:10 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
You can actually hear vacuum leaks with a stethoscope? I never have.
Old Sep 16, 2003 | 06:30 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I spray carb cleaner all over wehn im looking for a vacuum leak. when you spray over the leak, the motor will rev up.
Isnt "vacuum leak" funny? shouldnt it be an "Air leak" into the vacuum??
92camaroJoe
Jul 29, 2023 07:57 PM
89GTAOz
May 16, 2020 09:31 AM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
92camaroJoe
Aug 13, 2015 06:07 AM
