Does injector direction matter? (mine turn)
Old Sep 16, 2003 | 03:58 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
I installed 19lb/hr SVO injectors and found that they can be turned in their holes quite easily. Should it matter which way they are turned or is the spray pattern fully symmetrical 3D-wise? Thanks.
Old Sep 16, 2003 | 09:30 PM
88TAJeff's Avatar
Car: 88 T/A
Yeah it doesn't matter which way they're turned. Just how easily do they turn? They should have a bit of resistance.
Old Sep 16, 2003 | 10:23 PM
jamesbob02's Avatar
Car: 92 Z28
Well they wouldnt turn by themselvesjust by vibration or anything, its just that I'd never tried to turn my previous ones so I dont know if its normal or not. If the spray pattern is the same then I'm not concerned about it. They're definitely not leaking or anything like the seal is weak.
Old Sep 17, 2003 | 08:11 AM
88TAJeff's Avatar
Car: 88 T/A
Yeah you should be able to turn them back and forth.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
z28_AJ
Aug 27, 2015 08:59 PM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
