Injectors
Old Sep 18, 2003 | 10:18 AM
LUPPS's Avatar
Injectors
Guys i need help with my car. i have a 1992 z-28 5.7 on the passenger side the injectors sound pretty hard when i listen to them, and on the other side they soud softer? i have never changed the injectors, do i need to change them cause of the hard knocking noise? cause the car stalls when i have it on high rev. Any help would be appreciated.
Lupps
Old Sep 18, 2003 | 10:58 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
This thread has information about electrically testing injectors.
https://www.thirdgen.org/techbb2/sho...ector+test+ohm
There are other threads describing how to test for injector leak down too. Do a quick search on "Injector Leak" in the TPI section and you should find the information to properly test your injectors. Listening to them is not on the list of testing.
High RPM fuel problems are usually the fuel pump though. Injectors tend to be an "all of the time" type of failure.
Old Sep 18, 2003 | 11:07 AM
LUPPS's Avatar
Injectors
So what you are saying is that just cause it sound like a hard knocking noise doesn't necessarily mean that the injectors are bad?. If i were to change them anyway what lb. of injectors should i get?. and also fuel pump? any help would be great. my setup is as follows 5.7c.i 700r4 beefed tranny, all engine components stock.
thanks again.
Old Sep 18, 2003 | 11:37 AM
bnoon's Avatar
Stock 5.7L injectors are 22# units. Replace them as a full set. You can run other brands of injectors if you're willing to make some chip changes, otherwise stick to stock. Hit up the search on this board for known injector suppliers.
All injectors make noise. Yours may be going bad, but the noise isn't a way to test them even though the noise may be resulting from a bad injector. Check them for sure before you waste money replacing good parts.
I have never changed a fuel pump in a 3rd gen. I just know some of the symptoms and high rev surging is one of them.
Old Sep 18, 2003 | 11:43 AM
LUPPS's Avatar
Injectors
BNOON
Thanks for your help but i found out what was going on with my Z-28 my fuel pump just gave out on my just a couple of minutes a go. so i will replace the fuel pump and go from there i will let you know what happens then.
Thanks allot
Lupps
Old Sep 18, 2003 | 11:54 AM
bnoon's Avatar
I think our cars have a fuel pump relay too, so you might check that before going through all of the work to remove the fuel tank to get to the pump.
Old Sep 18, 2003 | 12:00 PM
LUPPS's Avatar
Injectors
yeah! i checked that and that is not bad,i have checked the fuel pump by checking the current and there is no current, although i have also checked when i turn on the switch i does not make that humming noise. thanks
Lupps
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
