CARB -> TPI....worth it?
Old Sep 19, 2003 | 04:24 PM
MonteC's Avatar
Car: 86 Monte Carlo SS
Engine: LC2
Transmission: 2004r
Axle/Gears: 3.42 8.5" 10 bolt posi
is it worth the time and effort to convert from carb to tpi. as of now i have an 86 monte carlo ss l69 carbed, i have a chance to get a hold of a complete 87 trans am w/ a 305 tpi. that year trans am has maf which to my understanding is more desireable than SD correct me if im wrong. would it be worth the gains to convert to tpi?
Old Sep 19, 2003 | 05:09 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Personally, I wouldn't waste my time putting a TPI on any motor. There are much better alternatives out there.
Old Sep 19, 2003 | 05:14 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
and no...SD is more desirable on our cars. less finicky...less parts to break
Josh
Old Sep 19, 2003 | 06:02 PM
MonteC's Avatar
Engine: LC2
Transmission: 2004r
such as?
Old Sep 19, 2003 | 07:21 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
such as.....CARB.
but if you're looking into fuel-injection, you might try the Holly Stealthram.
However, if you're going for a show-car look and not worried too much about the power side of it (unless you've got some $$$ to spend on that TPI), the TPI can be polished to a mirror shine and is a nice addition to most classic hotrod's looks.
Old Sep 22, 2003 | 03:13 PM
MonteC's Avatar
Engine: LC2
Transmission: 2004r
what does that black dot on the chevy logo by my post mean?
Old Sep 22, 2003 | 03:17 PM
87350IROC's Avatar
Car: 87' IROC
If you're sticking with a 305 the TPI should be fine. SD has more power out of the box, however MAF is better for modifications. It learns things like cams nicely whereas SD you would definatly need to tune the prom. Don't get me wrong, prom tuning is an excellent tool but some people don't have the time or desire to do it.
Old Sep 22, 2003 | 06:44 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
Monte, the black dot means it is a post that either you started or you replied to.
Old Sep 22, 2003 | 07:07 PM
MonteC's Avatar
Engine: LC2
Transmission: 2004r
i was looking to get good gas mileage, and a few guys ive talked to have dont similar swaps from carb to tpi and got upto 22 miles to the gallon. but i guess if im gonna go through all the trouble of swaping in tpi i might as well swamp in an Lt1 instead.
Old Sep 22, 2003 | 07:47 PM
87350IROC's Avatar
Car: 87' IROC
I think your gonna regret a LT1 on a 305 unless you plan on spinning it to the moon.
Old Sep 22, 2003 | 07:53 PM
MonteC's Avatar
Engine: LC2
Transmission: 2004r
no intead of putting in a 305 tpi, i figured i might as well swap in a complete lt1 engine from a late model z28, and ditch the 305.
Old Sep 22, 2003 | 07:56 PM
87350IROC's Avatar
Car: 87' IROC
oh, ok, now there's an idea
Old Sep 22, 2003 | 09:09 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
I think that there are a ton of great deals on complete LT1's with computer and harness on the web. I kind of wish that I had bought an LS1 complete setup instead of my ZZ4 setup. The LT1 is more serviceable than the LS1 and has great potential for power as well.
Old Sep 22, 2003 | 09:27 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if by TPI you mean the wiring harnness, computer and overall injection system with a good intake, then yes swap to EFI
if you mean a bone stock manifold TPI, no.
Old Sep 24, 2003 | 10:54 AM
MonteC's Avatar
Engine: LC2
Transmission: 2004r
yes, im just trying to go fuel injection instead of carb cause the carb is not that good on gas. id love to put an ls1 in my car but that would require major modifications. if i can find a good deal on a complete lt1 ill go that way but if not ill go tpi either 305 or 350.
Old Sep 26, 2003 | 06:12 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
so how much are we looking at here for a lt1 on the net? I would love to swap an lt1 into my Z....i hate having an LG4
Old Sep 30, 2003 | 03:58 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
www.tacreationsusa.com
sells complete lts with 6 speeds
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
