out of depth
Old Sep 21, 2003 | 06:49 PM
irocnz's Avatar
Car: 1986 Iroc Camaro
Engine: 406 small block
out of depth
My 86 Iroc 305 TPI has a problem when you back out of the throttle. It will cruise along then the engine sort of dies then runs ok without doing anything.This will happen 3 or 4 times.When this occures the tach goes from up and down from 1500 rpm to 0.Service light on, 33 & 34. Have replace o2 sensor, check connections. Can an 86 be read on a laptop?
Old Sep 21, 2003 | 08:05 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Jusy curious, but you have MAF codes, yet you changed the O2 sensor...any reason why?
'86 should be a '165' ECM, so yes, you should be ale to scan it.
Old Sep 21, 2003 | 11:10 PM
irocnz's Avatar
Originally I had a 13 code (o2 sensor) replaced that and had this problem since. Also now the cold injector is not working all the time making it hard to start. Under throttle the car runs fine?
Old Sep 22, 2003 | 12:56 AM
bigals87z28's Avatar
Car: Check The Sig
wow... 33 AND 34? they both are totaly opposite of eachother. I sugest you get a SU 145 Wells MAF. Someone will post the site here that you can pick it up for around $160.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
REZN8R
Car Audio
84
Sep 30, 2002 03:25 PM
88 427 Camaro
Mar 20, 2001 06:39 AM
john5.7 87Iroc
Car Audio
Nov 15, 2000 12:07 AM
