Bad injection problem
Old Sep 25, 2003 | 08:25 PM
Iroccer's Avatar
Car: Irocs and only Irocs
Engine: prefer 350s'
Transmission: corvette 700r4s'
I have 4 injectors that fire and 4 that don't I'm going to burn this car pretty soon if i don't get this solved .They were just chemically cleaned . Is it possible there was a service bullitin that said injectors for an '87 Iroc can't be cleaned chemically?They all have power and they seem to test electrically the same. but the inectors on the driverside don't work got any ideas?
Old Sep 25, 2003 | 09:08 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
if 4 fire and 4 don't, you have a bad injector driver module. Replace your ecm and turn the key, voila!
Old Sep 26, 2003 | 12:08 AM
RP1987GTA's Avatar
or a bad fuse...or wiring
Old Sep 26, 2003 | 01:33 AM
Morley's Avatar
Yeah. I'd bet on the fuse before the ECM, give it a look.
Old Sep 26, 2003 | 07:54 PM
Engine: 5.0 TPI
if it was a fuse, the whole computer would be down. If it were wiring, it wouldn't shut down exactly one bank of injectors. This scenario is way to clean cut to be some weird wiring problem or something else. One of your injector drivers has gone bad, that's all there is to it. Sh*tcan the ecm, because it's toast.
Old Sep 26, 2003 | 08:42 PM
RP1987GTA's Avatar
each set of 4 injectors has its own fuse....geez where do people get their info???the injectors are powered all the time.....the ECM is the ground path
Old Sep 26, 2003 | 09:38 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Morley and RP1987GTA are correct, there are two fuses for the fuel injectors. One for the even numbered injectors and one for the odd numbered injectorsAnd no , the whole computer would not be down if it was a fuse.
The Trickster!!!!!!!!!!!
Old Sep 26, 2003 | 10:54 PM
Iroccer's Avatar
Ok To check the fuses first where do I find them ? Are they in the fuse box or located under the hood some where. I have never been into the electronics of the fuel system before. I can't tell you guys how much i appreciate this help.
Old Sep 27, 2003 | 02:01 AM
Morley's Avatar
On the fuse block. Should be labeled Inj1 and Inj2
Old Sep 27, 2003 | 11:22 PM
Iroccer's Avatar
Thanks guys, it was just the fuse. I figure the circut shorted out when the #1 injector started to leak from inside the plug. It runs great again. I will come here for all my info from now on. I want you all to know I really appreciated the help . Thanks again!
86IROC112
Apr 9, 2016 10:20 PM
toronto formula
Nov 10, 2015 06:17 AM
Reddeath210
Oct 6, 2015 08:20 AM
dyeager535
Aug 28, 2015 08:10 AM
Bryan F
Aug 18, 2015 02:28 PM
