Dyno Tuneing 1 results
Old Oct 3, 2003 | 12:37 PM
Shaun 90 Iroc's Avatar
Car: 1990 Iroc-Z
Engine: 350 L31 Vortec
Previous #'s 252.9 & 376.4 to the wheels.
We adjusted the fuel pressure to about 44.5 to get a 12.1-13 A/F ratio across the rpm's.... the machine was messing up so we are unsure how accurate the reading.. but its not spittin black smoke.. so its a lot better. We advanced the base timeing from 8-10 as well. I gutted the air boxes and added a crank pulley...
Over all the #'s were 261.5rwhp and 385.5rwtq SAE corrected.
BUT! at 4800 rpm's the hp jumped about 15-20 still pullin 250rwhp at 4800.
Overall the car pulled to 5000 rpm's about 2 seconds faster then before.
Flywheel hp figureing in 20% drivetrain loss is:
327 hp & 482 tq
All with stock TPI plenum and runners.
How much hp gain and tq loss or gain do you see from:
SLP runners siamesed and a 52mm Throttle body?
Is it worth it?
Old Oct 3, 2003 | 02:24 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
You wouldn't happen to have access to the Ed Wright chip through the ALDL port, would you? I would love to get a look at his spark table.
I too am running Vortec heads with stock Plenum and Runners along with stock cam as well. I just ordered a set of 1.6 GM Performance Roller Rockers and plan on porting a plenum and siamesing runners.
My problem is I am not sure I have the spark table optimized for a fastburn head so I would like to get a look at an "experienced" person has done and work from there.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
ndndndnd
Sep 28, 2015 08:00 AM
JSDaddy189
Sep 26, 2015 03:50 PM
R13_Braz
Sep 18, 2015 05:00 PM
