no start
no start
i have a 1991 Z28 with a 305 tpi. heres my problem...she ALWAYS starts up perfect...but today i started it up 2 move to another spot, shut it off, then tried to restart 5 minutes later with no crank at all...it seems like my problem is somewhere in between my ignition lock cylinder and starter relay because it does not seem like my relay is energizing when i key-up...HELP! have any of you guys had any similar problem? thanks in advance
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Go over to the electronics forum and read a post by camaro of solar. you are both having similar problems. The replies posted there should be of some help to you.
His post is titled "car won't crank...wait 5+ minutes"
The Trickster!!!!!!!!!!!!!!!
His post is titled "car won't crank...wait 5+ minutes"The Trickster!!!!!!!!!!!!!!!
92camaroJoe
Aug 13, 2015 06:07 AM
