what would my compression ratio be with 72CC heads
Old Oct 9, 2003 | 10:00 PM
BOTTLEDZ28's Avatar
Transmission: A4
What the compression ratio figure out to be with a 72CC head on a stock 350 with stock pistons?
Old Oct 9, 2003 | 10:05 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Try thishttp://www.prestage.com/Car+Math/Eng...s/default.aspx
Old Oct 9, 2003 | 10:15 PM
BOTTLEDZ28's Avatar
Transmission: A4
just ried but I dont know what the numbers are for deck height, gasket thickness and valve reliefs is can you run me some numbers so I can get an accurate ratio
Old Oct 9, 2003 | 10:39 PM
shaggy56's Avatar
Car: 71 Nova
Your stock gasket is .028 compressed thickness. I believe your valve reliefs are 7cc stock. This info was from parts for your car. Im haveing trouble figuring your stock deck height. I know deck height is usually an average number amongst most sbc.
Old Oct 9, 2003 | 10:45 PM
BOTTLEDZ28's Avatar
Transmission: A4
what about valve reliefs on stock pistons? the stroke is 3.48 right? how much bigger does the bore get to displace 355CI and what is the stock deck height
Old Oct 9, 2003 | 10:47 PM
shaggy56's Avatar
Car: 71 Nova
355 I believe is .030 over. And yes about the stroke. Finally your stock deck height should .035. Im guessing 72cc is about 8.79:1 compression on your stock setup. Would be nice for a blown motor.
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
86IROC112
Aug 21, 2015 07:20 PM
