Code 36 "Mass Airflow Burnoff Circuit"
Old Oct 12, 2003 | 02:10 PM
Mgilb18's Avatar
My car is currently givivg me this code. The SES light stays on all of the time however the car still runs nicely. Do you think that by replacing the burnoff relay that it would more than likely take care of this problem? Also, is the burnoff relay, the same as the power relay? Thanks for the help!
Matt
Old Oct 12, 2003 | 02:43 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
I have this code 36 for years now!
Replaced and cleaned almost everything,stil this f...ing code.
Sometimes it will go away for some time, but in the end it pops up again.
My car as well runs fine, so I don't worry.
When I clear the code(s) by disconnecting the battery for some minutes,it (code 36) wil stay away for some time, try that as well!!
And yes, the relays are the same for the fuel pump, maf and the burn off system, they are not expensive, so replace them all, you may be lucky!
Old Oct 13, 2003 | 02:14 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I was getting the same code with my car. I replaced the burnoff relay and it worked fine. You should be able to pickup the relay at Autozone for about $10.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
