Temp gauge malfunctioning?
Old Oct 15, 2003 | 05:23 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Well, upon initial start-up, the cars temp rises to a nice operating temp. However, once shut down, upon restart, the temp gauge stays pegged right around 100' and stays there. What gives? Bad gauge or bad sensor, the sensor appears as though it was just changed, the threadlocking tape is still bright white. Any ideas? Are these gauges jst as bad as the oil pressure as far as accuracy??? Thanks guys
Will
Old Oct 15, 2003 | 05:30 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The coolant temp guage in these cars isn't anywhere near as bad as the oil pressure guages so you're not likely chasing a phantom known bug.
Other than that:
Cold = high resistance
Hot = low resistance
Feel free to troubleshoot the problem yourself using the facts above. I.E. when the needle is doing it's stuck low thing, disconnect the wire and ground it. Needle should peg high. If not, the guage is ignoring the sender, or the wire has an intermittent break.
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
corey8084
Sep 17, 2015 02:56 PM
