cam opinions?
Old Oct 15, 2003 | 06:09 PM
jbbiggs's Avatar
Car: 95 formula
Transmission: 4l60e
cam opinions?
I'm installing a flat tappet in a 85 350 tpi thats opened up pretty good, 2.02 1.60 ported heads intake etc.....
here's the specs
.050 214* 224*
LIFT .442 .465
Let me know what you think
Old Oct 15, 2003 | 06:45 PM
conlinj's Avatar
I'd run a comp cams xtreme nrg summit number cca-12-236-3
218/ 224
.462/.477 w/1.5
.493/.509 w/1.6
112 LS
the lobe profile on that will be real nice and it's a 1300-5500 power band perfect for a tpi setup. The cam u have will be pretty mild most guys use a cam like that in 305's Your 350, specially with those valves in your heads, will flow more air then that cam can use.
Old Oct 15, 2003 | 06:50 PM
jbbiggs's Avatar
Car: 95 formula
Transmission: 4l60e
218/ 224
.462/.477 w/1.5
.493/.509 w/1.6
112 LS
How about that 112 LS is that ok with the tpi?
Old Oct 15, 2003 | 06:51 PM
conlinj's Avatar
that's what you want with the tpi, but no less
Old Oct 15, 2003 | 07:18 PM
jbbiggs's Avatar
Car: 95 formula
Transmission: 4l60e
HOW ABOUT PROGRAMMING?
Old Oct 15, 2003 | 07:36 PM
conlinj's Avatar
you could contact ed wright at fastchip, burn your own, or find a tuner in your area
Old Oct 16, 2003 | 05:13 PM
conlinj's Avatar
also you have an 85 which is a maf setup, which will self tune, not as good as having a chip burnt but better then a sd car would react to the cam change
Jorlain
Oct 8, 2015 01:57 AM
88rscamar0
Sep 23, 2015 09:08 PM
Jlanz55
Sep 8, 2015 11:28 PM
TheExaminer
Sep 7, 2015 08:34 AM
Strick1
Sep 4, 2015 07:11 AM
