nned quick answer on the 219 cam
Transmission: A4
I have a HSR and AFR 195 heads on a 350 enigine. I need a cam. Will the 219 lingenfelter cam be great for this combo or can I do better? i ask because there onebay for only $250 right now and I know a lot of people say this cam really rocks. Car is a street driven car mods are in signiture
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
LPE 219 is a single pattern cam and usually is recommended for "tuned port" intakes like Superram. Short inktakes like miniram, LT1, HSR usually likes dual pattern camshaft.
I think you can get a better camshaft for the HSR, do a search I know "best cam for HSR" posts have been up before.
/N.
/N.
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
I am going to agreee with these guys on not using the LPE 219 for the HSR, that cam just seems to work only for the SR on a 350, and SR only...but if you decided to go with it..let me know I just posted my LPE 219 for sale for less that 250.
Originally posted by BOTTLEDZr28
more gear,, there aint no way Im going to a 4.10 gear. You really think it would help though?
Right now, no.....but if you go with a cam like I mentioned before, yes! Reason being your powerband will be up higher and you need the gear to keep you there. Plus it will help with launching. Keep in mind that most T56's have a 2.66 first gear.
