Need some quick help
Old Oct 16, 2003 | 08:56 PM
gtpfbod's Avatar
Im re-installing my tPI unit after porting it and I came across a part and I can remeber where it goes. Im sure it hooks into the plenum.......but what does the other end hook to. Im thinking it hooks into the tube coming of egr valve in the center of my lower intake. Here's a picture of the part
Old Oct 16, 2003 | 10:20 PM
stuart's Avatar
Car: 88 gta ....89 formula 350
Engine: 5.7......383
Transmission: heavily reworked 700r4
it looks just like the one i have and it goes from one of the side ports on the plenum to the egr valve.....hope this helps.......
Old Oct 16, 2003 | 10:32 PM
llvll4l2c91350's Avatar
vaccum line to the fuel pressure regulator. the EGR line is much longer
Old Oct 16, 2003 | 10:41 PM
stuart's Avatar
my bad, after looking i stand corrected.........
Old Oct 16, 2003 | 11:52 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Yeah I agree, I think its the FPR line.
Old Oct 17, 2003 | 11:32 AM
gtpfbod's Avatar
thanks guys, Is it supposed to fit in the FPR tight....because it seems kind of lose to me
Old Oct 17, 2003 | 11:38 AM
Morley's Avatar
Thats because you broke the metal nipple off of the regulator housing (piece sticking out of the 90 degree conector in your picture)
Old Oct 17, 2003 | 02:56 PM
jamesbob02's Avatar
Car: 92 Z28
Yeah. Looks broken.
Old Oct 17, 2003 | 11:00 PM
gtpfbod's Avatar
That sucks...so I guess I gotta buy a new one then.......
Old Oct 18, 2003 | 02:28 PM
jamesbob02's Avatar
Car: 92 Z28
Get an adjustable one while you're at it. You won't regret it.
Old Oct 18, 2003 | 11:50 PM
gtpfbod's Avatar
i already have a BBK........
Old Oct 19, 2003 | 01:10 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
if thats the vacuum nipple for the AFPR then if your very very carefull you can JB Weld it back on (I did it to mine) if its not, then you can also get a regular piece of vac line but youll have to go with a longer one and loop it so you dont kink it. I hate that plastic crap usually every time you move it, it will break on ya.
Old Oct 19, 2003 | 07:38 PM
jamesbob02's Avatar
Car: 92 Z28
Ouch that sucks. Yeah use some JB weld and put it back on. Be careful, and dont get any inside the tube or inside where you're putting it back on. Should work.
Old Oct 19, 2003 | 10:44 PM
gtpfbod's Avatar
yup, we jb'd it back on....thanks for your help guys....
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
