Corvette runners
Old Oct 17, 2003 | 09:58 PM
onebinky's Avatar
Corvette runners
Hey guys-
Is there any performance benefit to fun stock vette TPI runners over my stock 305 TPI runners? I have seen a couple sets of vette runners in person, and they seem to use a larger diameter and a shorter length pipe. I just found a set online going for reletively cheap. Will I see any difference in running these over the ones I have?
Here's a pic
Thanks for any input guys
Matt
Old Oct 17, 2003 | 10:40 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
They are exactly the same. The runners for all 305/350's are the same, aside from the change in 90 when they got rid of the cold start injector. I have noticed that on the vettes and on 92 f-bodies with tpi the casting is a lot rougher than the previous f-bodies.
Old Oct 17, 2003 | 11:00 PM
onebinky's Avatar
Well that stinks, I thought I found a cheap performance mod. Maybe I'll just siamese the ones I have when I do my heads/cam, that should make it breathe a little better
Thanks for your thoughts 91TPI
Matt
Old Oct 18, 2003 | 01:58 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Vette runners look bigger because the tubes are a bit different. They have a rough cast finish on the outside instead of the smooth finish that the f-body runners use. That's the only difference. Inside diameter & length is identical.
Linson
Oct 24, 2025 02:00 PM
Royal_Z
Sep 30, 2015 08:45 PM
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
