Throttle Response?
Old Oct 18, 2003 | 12:13 PM
Syxx613's Avatar
Car: 1987 Trans Am GTA
Transmission: 700 R-4
Throttle Response?
I seem to have an issue with my throttle response. When i step on the gas it takes a second or two to pick up. I just chaged cap, rotor, and oil, and i have a brand new K&N air filter. It doesnt rev up or anything, it just doesnt do anything for a second and then will start to pick up a little slower than i tend to remember. Any help?
Old Oct 18, 2003 | 03:12 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Have you changed plugs, or fuel filter lately??? If not do those first and see if that helps. I always do the tune up things first before I get into the more expensive stuff.
Old Oct 18, 2003 | 09:14 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
yeah,do the plugs n wires. and do the fuel filter and check the fuel pressure.
Old Oct 19, 2003 | 12:48 PM
Syxx613's Avatar
ok, no prob with the plugs i got those and im getting some wires this week. However, i am finding it extremely difficult to change the spark plugs. Any tips from anyone on changing the plugs? Also is there anything i should know about changing the fuel filter or do i just unscrew it and replace it? And how do i go about checking my fuel pressure? sorry for all the questions, this is my first TPI car.
Old Oct 19, 2003 | 12:55 PM
llvll4l2c91350's Avatar
before you replace the fuel filter it's a good idea to relieve fuel pressure by disconnecting the fuel pump fuse and lettin the car run until it dies. then just loosen the lines. will probably still have some fuel in the lines.
to check fuel pressure you connect the gauge to the valve on the passenger side fuel rail. also might wanna relieve fuel pressure beforehand.
some plugs you'll have to get from the top, others from the bottom. when installing new ones put a little bit of anti seize on the threads.
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Damon
Sep 26, 2015 04:29 PM
BWilcox
Sep 20, 2015 12:19 PM
