quick question about changing fuel filter.....
Old Oct 19, 2003 | 11:49 PM
KYL98's Avatar
Car: 1991 Z28
I need to change my fuel filter tonite on my wife's 88 IROC...since she has to leave for work tom. I have changed them before on my previous cars....etc. I cant remember the easiest way to relieve fuel pressure....the wire(s) or plug by the batt. or the plug above the fuel tank.????? Also, since the car is on ramps I have another question.....when I take off the old filter, I know some fuel will come out from being in the lines....BUT, since the car is elevated downward from being on the ramps...will the fuel keep coming out of the tank??? Or does the pump not let anymore go thru after you relieve the press?? Please forgive the ignorance....havent done this in a long time. I need some immediate help as the car is up on the ramps now....thanks in advance guys.....
Old Oct 20, 2003 | 08:42 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I just remove the fuel cap. The official way is to pull the fuel pump relay & run the engine until it dies. You are always going to have some fuel run out, but it wont drain the tank as long as the pump is not running.
Old Oct 20, 2003 | 11:11 AM
KYL98's Avatar
Car: 1991 Z28
Thanks Rick, Ive always heard you could do that with the cap...but wasnt sure. Thanks again......
Old Oct 20, 2003 | 11:47 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The oil pressure switch bypasses the fuel pump relay, so disconnecting the FP relay isn't going to do anything for you.
The only way to kill powet to the fuel pump without turning off the ECM too is to disconnect the connector by the tank in the back. And since you're already laying under the back of the car to do the FF anyway, it's no big deal.
And yes it takes a couple minutes for pressure to go down running it like this.
And yes fuel will syphon out constantly when you disconnect the fuel filter. Be ready to operate fast.
Old Oct 21, 2003 | 11:09 AM
KYL98's Avatar
Car: 1991 Z28
Thanks Ed....I got it last nite....it was like changin the coolant temp sensor or the knock sensor...lol I had to work fast. I dont think I lost that much fuel. Car runs MUCH better now. Thanks guys for all the help.....
Old Oct 21, 2003 | 01:21 PM
Guest
Guest
Posts: n/a
Just disconnect it and forget about taking pressure out of the system.
Old Oct 21, 2003 | 03:09 PM
Ricktpi's Avatar
I have done this many times on several different GM vehicles including my 87 Z & 00 Silverado. After the intial few ounces drain out of the line, that's it, no siphoning action with the cap off.
Old Oct 21, 2003 | 03:15 PM
KYL98's Avatar
Car: 1991 Z28
Wouldnt that cause fuel to spray out? Im going to change the filter on my 91 LT1 Z in a few hours.....I wasnt so worried about my wifes car as it has the original pump. But, my car has a brand new Walpro pump....much stronger than the old stocker. Im thinking I should disconnect the plug above the tank and let it run until it dies.....would that be sufficient?? I just dont want to get sprayed with fuel....its really not fun..lol
Old Oct 21, 2003 | 05:35 PM
Guest
Guest
Posts: n/a
1. You can siphon the tank dry. Happened on my 86. Dont know why, it never did it before.
2. Yea, fuel will leak/spray out. Get yourself a shop towel and wrap it around the line. It'll just about saturate the towel, and thats about it. No big deal IMO. Been there, done that too many times to count. Also the pump you have doesnt matter, the line pressure is the same. Thats what you are dealing with, not volume.
Old Oct 21, 2003 | 05:46 PM
KYL98's Avatar
Car: 1991 Z28
ok thanks guys. Just wanted to make sure before I blew myself up..lol
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
92camaroJoe
Aug 13, 2015 06:07 AM
jahblah
Aug 12, 2015 05:54 PM
