Fuel reg ??????
Old Oct 21, 2003 | 11:04 AM
kustom71's Avatar
Fuel reg ??????
If the regulator lets the pressure bleed off after you shut off the engine it really wouldnt cause any problems would it ezcept maybe crank an extra turn or two when starting?????
Old Oct 21, 2003 | 12:09 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
My AFPR bleeds down within 10-15 miinutes or so of shutting the car off. Doesn't really matter though since after a few minutes off the ECM will reprime the FP anyway.
If it leaked down VERY fast though i suppose you could have a slow starting problem.
Old Oct 21, 2003 | 12:22 PM
Steve89GTA's Avatar
Mine does the same things, except. If I shut it off and wait like 5minutes and go to start, the idle will be a little high. I think my injectors are leaking fuel into the chamber when I shut it down..
When the car is warm and I let it sit for and hour or so, I have an extended start time followed by a puff of smoke, then start.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
3rdgenparts
Aug 6, 2015 09:03 AM
