Airflow modifications
Old Oct 24, 2003 | 03:14 PM
MasterEvilAce's Avatar
I've realized recently that the airflow setup on our TPIs are really, really limited. Or atleast it seems that way.
Does anyone know the name of those air filters that attach at the end of the TPI plenum thing... Is there anything extra required? how much do those things cost?
and can anyone actually feel the improvement of using one? Seems like you'd get a LOT more air into the engine that way (although, warmer air)... anyone with any dynos of before/after? unlikely, but the more detailed the better
and if you have one, what'd you do to cover up the area where the normal setup attached to the front end of the car? (over up the holes)
or is there someway to fabricate it (or leave them open, if it works that way) so the engine gets more cool air?
Old Oct 24, 2003 | 04:30 PM
92RSZ's Avatar
Car: 91 Z-28
Engine: 420 sbc
Axle/Gears: 12 bolt/4.10 gears
dont waste your money on one of those. all it does is make a lot of noise and suck lots of hot air right off of your radiator. cut the bottom of your stock intake off and get some type of ducting to connect it to the space behind the foglights. i had one of those before and you can feel it kill performance.
Old Oct 24, 2003 | 08:24 PM
on the black piece, though, that connects over the filters
it has a slight up-shift at one point.. it looks like it really doesn't allow enough room for air
so this isn't really a problem?
Old Oct 24, 2003 | 09:26 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Those cone filters are designed for SD cars. You can convert your setup to a ram-air style and will gain a few extra ponies that way.
Old Oct 25, 2003 | 10:09 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The stock camaro airbox doesn't even become a slight restriction until you are well over 300hp. Save your money for something that really helps.
chazman
Aug 28, 2018 03:25 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Nervous2
Oct 8, 2015 10:53 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
chazman
Aug 22, 2015 02:01 PM
