Need some suggestion Please
Old Oct 26, 2003 | 01:07 AM
Tad's Avatar
Tad
A little histroy first:
Have 87 comaro that was originally an LG4. Was convert to a 350 with GM ZZ3 conversion kit. Now I converting it to a TPI with speed density system. Now the problem has been trying to get it started. It won't fire, Its not the Vats burn my own chip for that. Not timing have double check that. It is getting spark to the plugs. Is getting fuel to the rail. But doesn't seem to get past the injectors. Have an injector tester that checks the injectors and harness. the injectors check out fine. But when I check the harness it wil only show that it is plusing the injectors for less then a second while you are cranking the motor. Does anyone have any ideas what it could be? Any help would be very much appreciated.
Tad
Have already tried a new computer.
Old Oct 26, 2003 | 01:13 AM
Morley's Avatar
Make sure the distributor wire leading to the ECM is hooked up, if the ECM can't see the ref pulses from the dist, it won't fire the injectors. sounds like the fuses are ok if the injectors fire for that 1 second burst.
Old Oct 26, 2003 | 08:25 PM
Tad's Avatar
Tad
Thanks I will look into that tonight when I go to the garage. Is there anything else that would keep the injectors form firing while you a cranking the engine.
Tad
Old Oct 26, 2003 | 09:41 PM
Morley's Avatar
Tad
Not if they fire for that first second
Old Oct 27, 2003 | 12:57 AM
Tad's Avatar
Tad
Did find that the timing bypass wire was not making a good conection. The injectors pluse longer now but still quits. pull spark plugs still not getting fuel in cylinder. Dont even have a faint fuel smell on them. Iam using MSD 6A. But don't think it would be causing the problem. Any other sujestion would be most appreciated.
Tad
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
