QUIK! What is the sensor next to the Coolant Temp Sensor?
Old Oct 29, 2003 | 10:55 PM
Black IROC 86's Avatar
Car: 1986 IROC Z
Fast Fast the stores bout to close and my mechanic is outside!!
Old Oct 29, 2003 | 11:00 PM
86_TA_LB9's Avatar
cold start...also a temp sensor.
Old Oct 29, 2003 | 11:39 PM
steven90GTA's Avatar
From: Tomball Texas, right outside (north) of Houston
Car: 1990 GTA and 83,99,02 Trans Am WS6
Engine: 350 TPI,CrossFire 305 and LS1
Transmission: 4L60 and 700R4 and 4L60E
Axle/Gears: 90-3.23,83-3.42,99-3.73,02-3.42
I think the only thing around there is above it near the throttle body and it is the IAC idle air control and above that is the TPS throttle position sensor
Old Oct 30, 2003 | 02:34 AM
bigals87z28's Avatar
Car: Check The Sig
i guess the store closed...
Only sensors i can think of is the IAC that is mounted to the TB, but its not a sensor. IAC Idle Air Controler.
Old Oct 30, 2003 | 02:39 AM
Car: 1986 IROC Z
Yeah thats it. Imma have to buy it tomarrow tho, store closed. How much does this run for? I took this sensor out and my coolant temp sensor and they both look like they have never been replaced, like if they were the factory ones. Stupid *** last owner only cared for looks not for anything under the hood.
Old Oct 30, 2003 | 12:13 PM
86_TA_LB9's Avatar
when i went to napa to replace my cts, i had aken the cold start sensor out not knowing what it was. the guy spent at least a half an hour flipping through books before he found out what it was. also it was around 50 bucks and he had to special order it...it was covered with deposits from the coolant, but 50 bucks was a little much so i used some 300 grit sandpaper and polished it right up....no word on how well it worked though...
Old Oct 30, 2003 | 09:56 PM
Car: 1986 IROC Z
Kragen dont seem to have this. Niether does Auto Zone. I went to local auto stores also and they dont have it. What to do?
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
