Injector resistances..WTF?
ok earlier today i saw a post about injectors...there was something said about testing them with an ohmmeter and the resistances should fall between 14-16 ohms.
i tested mine just now and this is what i got
listed from the firewall to the front end
passenger side = 17.5, 18.5, 19, 19
driver side = 20.5, 20.5, 24, 25
the car is an 86 lb9 tpi auto...ive been having problems with a hesitation when i stomp on the gas, and it gets horribly bad under load. the car seems to lose all power for a second, and then it will go, but i know there should be more power. ive replaced the maf, and relays, coolant temp sensor,
air temp sensor, plugs, checked for vacuum leaks and found none, replaced the rotor in the dist. cap, checked the coil, checked the plug wires and they dont seem to be arcing, i ran fuel injector cleaner through the injectors, checked the fuel pressure, changed the iac and countless other things which helped a little bit but not totally...alsdo the car has a problem gettig started when cold and idles pretty badly also when cold. any help or suggestions are appreciated.
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
According to my Haynes manual (Firebird - all models '82 thru '92),
the factory fuel injector resistence is between 11-14 ohms.
I'm not a good enough mechanic to say that this is your problem, but it seems like the numbers you listed are too high.
I would recommend picking-up a Haynes manual (if you do not have one). They are about $15-$20 Autozone. Mine has come in handy many times since I bought my car.
If you do decide to replace the injectors, alot of people in the forum have been talking about the SLP injectors for $99.95
http://www.slponline.com/view_produc...RTNUMBER=23051
you might check them out. Myself, I went with Accel.
Hope this helps.
Hope this helps.
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I just got my injectors cleaned and matched by Rich at crusinperformance.com and he measured the ohmage of mine (stock 88 lb9)
Test pressure = 43.5 psi Injector No.
1 2 3 4 5 6 7 8
Test 1. Injector Resistance 16.3 16.2 16.2 16.3 16.2 16.2 16.2 16.2
Test 2. Leak Down Test (Pass / Fail) P P P P P P P P
Test 3. Spray Pattern (Good / Fair / Poor) G G G G G G G G
Test 4. 60 Second Pulsed Flow Delivery (mL) 55 52 47 51 50 50 53 51
Test 5. 100mL Pulsed Volume 100 95 86 93 92 92 96 93
Test 6. 20 Second Static Flow (mL) 76 71 63 70 69 68 72 70
Test 7. 100mL Static Flow 100 93 83 92 91 90 94 92
Test 8a. Injector Coil Test - On 8.04 7.99 8.03 8.04 8.01 8.01 7.99 8.01
Test 8b. Injector Coil Test - Off 8.09 8.04 8.08 8.09 8.06 8.06 8.04 8.06
1 2 3 4 5 6 7 8
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
100 bucks total to clean and service them. if you do a search on rich @ cruzin performance you will find this service to be highly recommended.
thejimsterz28
Sep 15, 2015 04:37 PM
