Cany anyone help me with MSD 6AL ignition and what I need?
Old Nov 5, 2003 | 04:13 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Hopefully I'll be coming into some money in the near future, and I thought I'd sort this out now... I'm planning on MSD 6AL ignition, superconductor wires, cap/rotor/coil. I have an '87 LB9. I'm pretty sure there's a 20-30$ kit needed for our coil or something for this kit right? Does anyone have the part # for it? Also, what are the best superconductor wires to get for my car, it still has stock manifolds... I'd want the straight boots right? If anyone could help me out with some part numbers or any little things I'll need that I'm missing, it would be greatly appreciated...
Old Nov 5, 2003 | 05:12 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
It's called a cap-adapt from MSD.
You need an external coil like a blaster from MSD.
You will need a low resistance bushing to go in the top of your cap so the current from the msd will not melt it.
Old Nov 5, 2003 | 07:30 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Transmission: 700 R4
Axle/Gears: 370 BW
"low resistance bushing to go in the top of your cap so the current from the msd will not melt it," could someone elaborate on this. I've had that setup for ages and never experienced any melting. How necessary is this resistance bushing and does it provide any other benefits?
Old Nov 5, 2003 | 08:34 PM
bigals87z28's Avatar
Car: Check The Sig
Re: Cany anyone help me with MSD 6AL ignition and what I need?
Well you dont need any thpe of kit for you coil as it should all come together. You should have an external coil like on my car. I have the MSD Blaster II and MSD wires on, but im going to go with the 6A. You should call up MSD and ask what you need. Maybe more people will come in here and tell you what they used.
Old Nov 6, 2003 | 01:29 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
I have the 6A in my vette and got Crane HI-6 for my Formula because it came with a free coil, it was a universal on but you can get a whole kit:
http://www.shopcranecams.com/hi6gmperkit.html
The crane unit is way smaller, I have some comparison pics at home if you want me to e-mail em to ya.
my73vet@cs.com
Old Nov 6, 2003 | 03:56 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I got mine from Summit a few years ago. I called them up & got the adapter harness with MSD 6. It just plugs the GM coil or the MSD replacent coil.
Fanatic1074
Oct 3, 2022 05:57 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
