Help tuning 268 Extreme Vortec heads
Old Nov 11, 2003 | 10:07 PM
walkerscott's Avatar
Hoping someone has a similair combination to help my tune a 165' ecm with the following 268 extreme comp cam vortec heads stock lower intake Injectors are stock 19# What size would be recommended also should I get an adjustable FPR .
I figure 24# injectors what is the most resonable deal on these?
Right now the car has a stumble what table do i tune to straight this out ! using winaldl and winbin...
Old Nov 12, 2003 | 03:53 PM
KYL98's Avatar
Car: 1991 Z28
Welcome to the board. You might try posting this over on the DIY-PROM board. Some other things to try.....read and re-read this article......https://www.thirdgen.org/newdesign/tech/promintro.shtml
It is really important to know how the TPI system works and more importantly, how an engine works, How changing fuel and spark affect the engine. While Im not sure about the 165 ecm, Id say your stumble is due to the cam's lack of vacuum at lower rpms.....but not 100% sure. Read ALL the articles on PROM tuning, then post on the DIY-PROM board....look for TRAXION on there...he'll help ya. Good luck...
Old Nov 12, 2003 | 03:55 PM
KYL98's Avatar
Car: 1991 Z28
FWIW, SLP has 25lb injectors for $99 right now.....check them out.
http://slponline.com/view_product.asp?PARTNUMBER=23051
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
