code 33
Old Nov 14, 2003 | 02:43 PM
fahq's Avatar
code 33
I have a problem with my 88 formula tpi 350 and 86 ta tpi 350.
They both keep coming up with a code 33. I did all the diaognostic
tests and it keeps telling me to replace the maf. I put a new maf on it is micro-tech. It defers from the original bosch. It keeps throwing the same code. Did anybody else use this maf (micro-tech). Any suggestions? Thanks
Old Nov 14, 2003 | 05:13 PM
hesgone2fast's Avatar
Car: 89 Trans Am GTA
Engine: 350 stock (big mods coming up)
Transmission: automatic for now (T56 coming)
The code might be stored on the memory, so you need to unplug the ecm plug that is located right next to the battery on the driver's side, there should be two black plugs, just unplug both, leave them unplugged for 2-3 minutes, and then plug them back in, if it keeps on showing the same code, them something else is wrong besides the maf.
Old Nov 15, 2003 | 04:57 PM
mckenzie's Avatar
try replacing the maf sensor.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
