Ramjet ZL1 502 engine
Old Nov 15, 2003 | 12:39 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Does anyone have this performance motor in their vehicle? If so, what size injectors does it have and do you have a part number. I am thinking of purchasing a set of 8. Thanks.
Old Nov 17, 2003 | 01:18 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
not many people (here atleast) can afford a $25,000 engine
Old Nov 17, 2003 | 02:43 AM
bigals87z28's Avatar
Car: Check The Sig
The ZL1 is not a 502.. its an all aluminum 454 with the ram-jet intake. 22k is a hefty price for 500+hp... I rather get the 454 Small block pushing 610 for 11k. That has alum heads... and im sure a small block will be lighter then a big block, even if it is aluminum.
Old Nov 17, 2003 | 09:35 AM
biggtime's Avatar
Re: Ramjet ZL1 502 engine
Why would you want those injectors? Do you have the same combo? computer? fuel pressure?
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
