Good mods for a reliable 305TPI...
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
Hi all, I am going to do some mods to my 88, and want to maintain a good daily driving attitude but be capable of some low 14's or high 13's N/A. The car is a 1988 Formy with 305 TPI, fresh rebuild 7K ago, M5 and 3.42's on 10 bolt. I was thinking along the lines of LT headers with true duals(like my 95, but with real mufflers), a good clutch, LT1 cam(or LT4 hotcam,I already have both due to my 95), LT4 valve springs, programming, and minor mods like CAI and such. I believe the LB9 heads are iron in 88, so some aluminum heads, too. Is this a possibility?
I already plan on doing a complete suspension to this car, lowering springs, APHR, LCA's poly bushings, new shocks/struts, etc.
TIA...
Edit: I forgot to add, I have some 24lb stock LT1 injectors off of my 95, would they help with the LB9 and programming, with aforementioned mods?
TIA...
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I read that 24lb are to big for a N/A 305 that said the 21lb 350tpi injectors are good for a 305 with heads cam etc.
I think it was in GMHTP
OK, cool, I was wondering about that. I figrured I probably wouldn't have that big of an issue with it, anyway.
And Hey HM Murdock, taking some time off LS1.com?
Yeah, it's been a while since I have been here, but I have a good reason to now...
Thanks for the info i was thinking of an AFPR and that just confirms it for me...
Car: 1987 Formula
Engine: 383
Aside from the valve springs, you shouldn't have to touch the heads to get to where you want to go. I've run 13.8 at 97mph with just bolt-ons. The camshaft should really wake the 305 up along with the suspension work, should put you solidly in the 13's. The key is getting the short times in the 1.90-2.00 range.
Car: 1988 IROC-Z
Engine: LB9
yeah i think the heads arent worth it for what u are lookin for...a healthy ingition, suspension help and new cam, AFPR, and intake mods will get u nice numbers...
