Timing Troubles
Old Nov 25, 2003 | 06:26 PM
BlackcamaroIROC's Avatar
Car: IROC
Engine: 350 TPI w/modifications
Transmission: th700r4 built with a vig stall
Timing Troubles
I've been having trouble smoothing things out with my car after head/cam swap. I set the timing to 6* BTDC with the EST disconnected when I hooked it back up the mark was bouncing all over the place while idling! and when I revved it it would smooth out but the mark would be very very advanced. another thing is that it would not rev over 2500 rpm? any ideas as to what's going on? I'm guessing this has something to do with the computer cause things seemed alright with EST disconnected; I haven't check for any codes yet though. car is a 350 TPI
Old Nov 27, 2003 | 05:14 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
There are a few things that can cause timing to jump as you described.
The distributor gear not shimmed properly
Distributor with worn bushings;
Loose rotor;
Worn timing chain with too much slack;
Roller camshaft not installed with thrust bumper and Torrington bearing and
A vacuum leak.
Did you remember to clear the error code after setting the initial timing?
Are you getting any other error codes?
Jake
bryan623
Mar 22, 2021 06:43 PM
backtothe80s
Sep 5, 2015 12:39 AM
Camarothatcould
Aug 20, 2015 08:49 AM
EFR2000
Aug 18, 2015 08:54 PM
