did 3.23 gears come in 86 iroc-z?
Old Dec 5, 2003 | 01:31 AM
ray royer's Avatar
is there a tag or code i can look to see what gears i have. a friend if mine checked it by turning the tires and says there 3.23's.the car is all original.
Old Dec 5, 2003 | 03:15 AM
Morley's Avatar
Should be a metal tag on the Diff with a code on it, its an RPO code. Getthe code and go to the main page for TGO and go to the RPO decoder and put it in there.
Old Dec 5, 2003 | 03:21 AM
biff85ta's Avatar
Car: 04 Vette
Does your car have a rubber plug in the cover for the diff?? If so on the drivers side in between two bolts there should be a tag which will give the ratio.
Old Dec 5, 2003 | 03:22 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
MY 86 HAD 3.23 RATIO FROM FACTORY.
Old Dec 5, 2003 | 05:04 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
As did mine (with an open rear). Caused alot of trouble when I thought it was 2.73s and ordered gears and such for a swap thinking it had a 2 series carrier...
Old Dec 5, 2003 | 07:54 PM
86 IROC's Avatar
If it's still there, look at the sticker on the inside of your center console lid - it should have a GU5 code. My car was a GU5 car from the factory.
Old Dec 6, 2003 | 09:26 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I have an 86' and mine has 3.23 gears from the factory the why I found out was counting the teeth and after I did the math I seen that the number of teeth for the ring and pinion gear where stamped on the ring gear
I read on another forum that the autos with 2.73's counld not manually put the trans in first with out taking out some blocking plate in the console is this true?
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Fronzizzle
Sep 8, 2015 12:10 PM
toyotekk
Sep 6, 2015 02:21 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
