Conversion Question
Car: 1991 Camaro
Engine: 383
Conversion Question
Im going from TBI to TPI what else would i need besides this setup?
http://www.thirdgenresource.com/inc/pdetail?v=1&pid=655
Do i need to get a chip or change any major things around? Im not sure on about anything for this conversion so any help would be appreciated.
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
What are you working on ?? Any info on your car ?? might wanna check on the EGR seleniod (can't see if it's there)Water neck off the intake doesn't look like it's there.. Air filter or filters,throttle cable...gonna need a fuel pump too for starters. Also there's a different mounting bracket for the coil from TBI and TPI.
Car: 1991 Camaro
Engine: 383
i have a 91 305 TBI and im looking to convert it to a 327 i have laying around or a 350. Im just deciding which one would be better for me to rebuild and i know i want TPI injection cause i think its illegal to go to carb in PA if the car wasnt origanally equipped with it.
