whts your 383 combo
Old Dec 8, 2003 | 10:05 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
whts your 383 combo
I'm toying with the ideas of a 383 for my iroc.
i wanna know what you have?
383's only
what intake, heads, cam, compression and bottom
NA,N20, FI
what kinda power are you making
I'm thinking about a 383 w/
AFR 195's
cc305 or cc306
HSR or superram
I'm looking for around low-mid 300's at the wheels
something that has a nice power curve and is somewhat steetable
Old Dec 8, 2003 | 10:53 PM
biggtime's Avatar
Re: whts your 383 combo
You can do that with a 350....
hsr
195 afr
lingenfelter219 or zz9 cam
9.5 comp
Old Dec 8, 2003 | 11:02 PM
Kandied91z's Avatar
and it will be much cheaper....
Old Dec 8, 2003 | 11:04 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
See - the 383 you have in mind would probably make more than that! You would have to use more restrictive stuff and/or lower compression (7.5 - 8.5). So, you would have big displacement but it would be held back. Less gas mileage than a 350 making the same power too! I could say more, but I think this is sufficent information. Constructive of course, just pointing out better interest maybe. So, the question now is, 350 combo or MORE power ?
Old Dec 9, 2003 | 05:43 AM
Engine: peanut LB9
its gonna be a 383 cause i allready have the block allready machined.
if the combo makes more power thats fine. i wanna make at least 330rwhp/375rwtq
TH700R4 and a 3.42 rearend
if the combo makes 425+whp I don't really want that much. ]
and i lie the idea of AFR heads and cc305 cam but i'm not sure with what intake.
Old Dec 9, 2003 | 07:22 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
For a good balance of power and driveability. My recommendation is to use AFR 190 heads with the LPE 74219 cam and either a HSR or a MiniRam. The car will have excellent driveability and will be able to hit the HP numbers you are looking for.
The CC305 and 306 will work better in an application where the cylinder heads do not flow as well on the exhaust side. The AFR's tend to have an intake/exhaust ratio in the 75-80% range.
Some may disagree with my choice here but I have assembled this combination of parts and the car ran 11.60's.
www.geocities.com/dzperf
Old Dec 9, 2003 | 11:13 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Here's my 383 combo:
Actual displacement is 385
.040" overbore
Cola 4340 crank
Eagle 4340 rods
SRP dished pistons
9.3:1 CR
AFR 190s fully ported/polished
Comp Cams valvetrain
Comp Cams bumpstick(blower cam to go with blower motor!)
Hooker long tubes
HSR, ported
No blower yet
Stock rear end for now
TH-350
Very reliable, very driveable...
Old Dec 9, 2003 | 05:54 PM
Engine: peanut LB9
what should i be looking for in a cam then something with equal intake and exhaust lift/dur. ?
Old Dec 9, 2003 | 08:15 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Go for the 276HR from comp. I think it specs out to 230/236 @.050". Many are very happy with it. I have a similar cam but it is ground different due to the fact that one day I should have a blower on this engine. Right now the car runs very well...
I would say you can always go bigger if you are still looking for more, but as a starting cam I think you will be very happy. I will probably go bigger one day, but only time will tell...
BTW, is your car going to be daily driven or more fun than function?
Old Dec 9, 2003 | 08:31 PM
Engine: peanut LB9
i was thinking abouit the 276hr
the 276hr grind comes a few ways i was looking on compcams website b4.
Old Dec 9, 2003 | 08:37 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Go with the one where the description uses fuel injection talk. I think there is mention on TPI in it. Its been awhile though since I skimmed there catalog...
Old Dec 9, 2003 | 08:59 PM
Engine: peanut LB9
I will later, i broke my steering coulmn right now. well my dad broke it
and i can't get the earing back in but thats another toipic
Old Dec 10, 2003 | 09:11 AM
86 IROC's Avatar
11SEC91Z
Another proven combination, my car uses a lot of the same parts.
Old Dec 12, 2003 | 06:18 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Here is my new combo...
383ci
4 bolt main roller block - align honed, decked
Eagle 4340 forged crank
Eagle 4340 forged rods
TRW forged pistons w/thermal coated tops, anti-friction coated sides
Moroso 6qt oil pan w/internal baffles
Moroso crank scraper
Moroso windage tray
Moroso oil pump (bolted and tack welded pickup)
AFR 195 aluminum heads CNC machined w/Hydra rev kit
Comp magnum pushrods
Comp 1.6 pro-magnum roller rockers
Crane hydraulic lifters
Ultradyne (Harold Brookshire now with Lunati) 284/292 Hydraulic Roller cam - 230/238 .565/.565 @ .050 114LSA
TPIS Miniram intake
Accel 30# injectors
Pioneer SFI spec 8" balancer
Miloden reinforced timing cover
Comp cams Magnum Double Roller timing set
SLP 1 3/4 headers Jet Hot coated
Fully balanced
Just got the new Walbro 255lph fuel pump in (factory unit could not keep up with demand) and had to replace the distributor. Now I will be able to start tuning.
As far as power, Harold (cam designer) said that this combo should be 460 'real' horsepower. We have our annual dyno gathering at the end of January so I will be able to get empirical data at that point.
I will hook the n2o up after we get the tune right n/a.
-Schultzy
Old Dec 12, 2003 | 06:33 PM
Engine: peanut LB9
thats what i was thihnking. a litle bit differnet cam tough.
are you finished yet? if so hows it run?
Old Dec 12, 2003 | 06:42 PM
Car: 1989 GTA
Yeah I have been driving her for a while just haven't been able to tune it yet due to all the normal little gremlins that occur. We did some data logging last night and I am sending it to Jesse (ski_dwn_it) who is helping me with the tune. I am still using the chip that we took a stab at to get her running. Needs WAY more fuel up top Harolds cams usually like that.
It runs great. To be honest after researching everything I was concerned that I was going a bit too big on the cam. I went with the 114 lsa for several reasons but one is that the computers seem to like it better. The car is extremely driveable. As a matter of fact, this car is still my daily driver. Idles real good. Drives around town like it was supposed to be this way. But get on it and she really comes alive.
I will reserve my comments about my complete lack of torque with the miniram until after the dyno
-Schultzy
Old Dec 12, 2003 | 07:48 PM
86 IROC's Avatar
-Schultzy
Amen brotha!
Old Dec 13, 2003 | 10:25 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
One thing that I've found when tuning a MiniRam'd motor is that it likes advanced ignition timing and all in by 3000 rpm. My best ET was with 38 degrees total timing on a 11.5-1 motor.
Old Dec 14, 2003 | 03:21 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
389 CID
2 bolt main.
Main Studs, Head Studs.
Eagle crank,
6 inch eagle rods
KB pistons 10.3 : 1 Comp.
Ported Vortecs with 1.6 exhaust valves
Comp Cams XR276HR
Crane Golds 1.5 RR's
SDPC Vortec base
Ported SLP semi-siamesed runners
Ported plenum
52 mm TB
Coated Hedman Headers
Old Dec 14, 2003 | 07:28 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Hey Warbird,
Are the numbers in your sig actual dyno numbers? Very impressive if so...
Old Dec 14, 2003 | 11:26 AM
Car: 1989 GTA
word
Old Dec 14, 2003 | 12:00 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
here's the setup i'll be using www.fl-thirdgen.org/mrr23/mrr23-18.html
did some DD2003 and found the crane cam i'll be using makes more power after 4000 rpm over the hr276-14 some of you are suggesting. the graphs are here:
HP
http://stealthram.com/dyno/cranecompcomparehp.gif
Tq
http://stealthram.com/dyno/cranecompcomparetq.gif
Old Dec 23, 2003 | 03:33 PM
1987-396-IROC's Avatar
Car: 1987 IROC-Z
Engine: 4 bolt 383
hey does anyone know if stock rods are safe at 400-500HP at the flywheel? useing a 383 that is.
Old Dec 23, 2003 | 09:11 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Probably not, but RPM is the real killer of engine parts...
Is it worth the risk?
Old Dec 24, 2003 | 07:20 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
4 bolt Roller Block
Scat 4340 forged crank
Scat I-beam 6" rods
KB hyper flat tops 10.5:1 comp.
AFR 195 heads
Comp XR276HR-8 cam
Stealth Ram
Holley 950 ECU
Old Dec 28, 2003 | 10:57 AM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
It's not in yet, but here's my combo:
2 bolt main roller truck block - align honed, 0* decked
Milodon 4 Bolt Main Caps
Eagle 4340 forged "H" rods 5.7"
JE forged pistons 8.5CR
Trick Flow Ported/Polished aluminum heads
Moroso HV oil pump w/welded pickup
Comp custom length pushrods
Summit 1.6 roller rockers
Comp roller lifters
Comp Roller cam - 218/224 .495/.502 @ .050 110LSA
HSR intake
Accel 36# injectors
ATI SFI spec 6 3/4" balancer
Jackson Gear Drive
Hooker 1 5/8 headers Jet Hot coated
Fully balanced and Studded(heads, mains, trans, dist, oil pan).
Paxton SN 89 w/9lb pulley
N2O. (after the tune)
I can't wait to get this combo in and tuned..
"Speed costs money, how fast can you afford to go?"
Old Dec 28, 2003 | 03:18 PM
Engine: peanut LB9
why that cam?
Old Dec 28, 2003 | 07:14 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
If directed at me, here it is. I like torque and hp, and according to DD, this cam gave a better balance of both. I threw about 30 cam profiles at it, and some gave more hp, but less tq, others had radical curves, and that's not what I'm after. This cam gave me a smooth curve, with a nice balance. That's why that cam.
Old Dec 28, 2003 | 07:53 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Above motor,, (at least according to DD)
Old Dec 28, 2003 | 08:15 PM
Engine: peanut LB9
i don't know how to post my dd results. but with my NA 383, its showing a really sweet power band. imo
----rpm------HP-----TQ
3000rpm---287---502
3500rpm---352---528
4000rpm---414---543
4500rpm---450---524
5000rpm---469---492
5500rpm---469---447
6000rpm---458---401
6500rpm---442---357
thats with AFR 195's and LPE 219 cam.
Old Dec 29, 2003 | 05:30 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Here's how I did it (not a computer genius here)
open the DD and your profile.
hold the shift key and hit the print screen key
open Power Point
hold the control key and hit the letter V
once your pic is in there, you have to crop it and make it fit the entire slide. ( I cropped 4" from the left, and 1" both top and bottom.
Save as a jpg,, and you're in there..
Hope it helps!! There is probably an easier way, but I digress.
Old Jan 7, 2004 | 04:15 PM
KhaotikRaje's Avatar
paint
If you don't have power point, here's how:
1.) Hit the 'print screen' button
2.) Open paint
3.) Hit edit --> paste
4.) Crop to fit
Old Jan 7, 2004 | 05:20 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
The details of my buildup can be found below, including a few pics:
http://www.mnfbody.com/memberpages/m.../Newengine.htm
Old May 9, 2004 | 02:27 PM
Engine: peanut LB9
ok the motor as o now wll be a 383 forged pistons, LPe219 cam AFR 195 heads and HSR kit. this is the intake kit i will most likly be getting for two rearson. i wanan stay FI and my father will be getting my old motor and trans.
i will be ordering a level III 700r4 and 2400 stall converter from 700r4.com
and this from summit. what do u guys think? HSR kit
WyClef
Old May 9, 2004 | 04:28 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
My motor is in my sig. It's a 12:1 comp. engine with a 4340 ESP crank, Forged Eagle H-beams, Wiseco pistons, AFR rev kit, AFR 210's that flow 300cfm, 58mm tb, and everything else you can upgrade in one of these motors. The car just put 375rwhp and 375rwtq, without adjusting the timing. My AFRatio started up at 11.8 at 3500 and ended up going to about 12.7 at 6500, which is good. I didn't have time to play with the timing, so I might get another 15hp or so. I think these #'s are good but I was hoping for 400+rwhp with this combo. Auto trannies are known to cost you 25-27% of your fwhp though, so that would put me at 500-525fwhp. By the way my buddy who owns the dyno races ASA stock cars with stock Ls1 blocks and stock heads. It crazy though, cause with a bigger cam, manual trans, and a killer exhaust, those engines put out 400rwhp. His happens to put out 430rwhp after he's tuned it on the dyno a zillion times. It's a dynojet by the way.
Old May 11, 2004 | 02:37 AM
CrazyHawaiian's Avatar
Car: too many ...
You guys with 383's: Would you recommend a crate motor or re-use the 350 block? Experiences? Costs? Thanks!!
Old May 11, 2004 | 04:26 AM
e-man's Avatar
Car: 89 formula
Engine: 383
CrazyHawaiian originally I was just going to rebuild my 350 then found out that the parts cost about the same for a 350 vs. 383 and the only real price difference was $200 to clearence the block.
Old May 11, 2004 | 10:15 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
383
2 bolt 1989 L98 block
Eagle Crank
Eagle H beams
Speed Pro 10:3:1
LPE 219
Super Ram
Trick Flow Heads
LS1 Injectors
No times yet. Running rich at the moment.
Old May 11, 2004 | 12:05 PM
Engine: peanut LB9
mko1980 how do u like teh lpe219 cam?
Old May 11, 2004 | 12:28 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I like it. No complaints. I only have about 40 miles on the new motor so no WOT runs, but it idles kinda smooth thump thump thump thump. Drivabilty is great. pulls 17in vacume at a 850 idle, but I plan on lowering the idle. I did get ansy once and chirped the tires but that was all lol.
Old May 11, 2004 | 12:41 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I am doing a "budget" 383. I am going to be running the following
89 350 truck block 4-bolt mains (.030)
Scat 9000 3.75 Crank
Powder Metal 5.7" rods
Speed Pro 10.3:1 coated pistons
228/234 .480/.494 lift 110LSA
Ported 083 heads (budget part)
Melling HV pump w/ pickup welded on
Moroso oil pan with all the goodies
Ported TPI (other budget part)
I have no idea what power I am going to be putting out but it is going to be nice to get the 305 out and put a 383 in. If I have over 280rwhp I will be jumping for joy although coming from a little over 200 anything is going to be nice.
Old May 11, 2004 | 03:21 PM
  #42
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Mkos1980 - When I originally built my 383, I had pretty much the same combo as yours. The car ran 12.0's all day long with mid 1.6 60ft times. That was a great combo on the street.
Old May 11, 2004 | 05:46 PM
  #43
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
Mine is in my sig, not times yet, still piecing it all together.
Old Jun 16, 2004 | 02:00 AM
  #44
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
heres what ill hope to have sometime
got the 383 short block (forged weisco flattops, h beam rods)
stealthram
58mm tb
36# injectros
220cc heads with 2.02/1.6 valves
234/244 int/ext .55 lift 112 LSB cam
1 5/8 headers
msd 6al w/blaster coil
and at least a 150 shot n20
the heads and cam are in the air as i dont know much about them but i will hopefully put 500 fwhp and at least 500 fwtq down!!!
wont really be on a budget tho and defenitly wont be timely saving all of it up, one part at a time!!!!!!
Old Oct 24, 2004 | 08:52 PM
  #45
88IROK's Avatar
Car: 1988 IROC
Engine: 383 Stroker
RE: Mkos1980
Mkos1980, do you have any problem with detonation running the 10.3:1 compression ratio?
What size injectors?
I'm looking at the same 383 setup and want to get it as close as possible to correct from the git go.
TIA (thanks in advance)
Old Oct 24, 2004 | 09:27 PM
  #46
Matt87GTA's Avatar
Mine is 10.7:1 and I never log any knock counts aside from startup and shut down ("false" knock anyways).
Old Oct 24, 2004 | 09:37 PM
  #47
88IROK's Avatar
Car: 1988 IROC
Engine: 383 Stroker
RE
On pump gas Matt?
Old Oct 25, 2004 | 12:02 AM
  #48
Matt87GTA's Avatar
Re: RE
Originally posted by 88IROK
On pump gas Matt?
Yep, 92 octane.
Old Oct 25, 2004 | 06:06 AM
  #49
88IROK's Avatar
Car: 1988 IROC
Engine: 383 Stroker
383 cornfusion!
I think I've read so many posts here on the 383 combo that I'm convinced there may be no correct answer, only opinions as to what combo works best.
I am already commited to going with a totally forged bottom end assembly, I want to spin to 6500 and have a history of beating small block on daily basis (they're cute when they scream).
BUT!
1) Can anyone explain in simple terms the pros and cons of a 5.7" rod vs a 6.0" rod ?
2) Can a 1988 350 roller block accept the H-Beam rods with the 3.75" stroke ?
3) Internal or external balance ?
Old Oct 25, 2004 | 10:05 AM
  #50
88IROK's Avatar
Car: 1988 IROC
Engine: 383 Stroker
ooops
sorry guys, i found the info i needed, just had to modify my search.
Moderator, please delete.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
